where is 'computer module'..to find factory keypad code? | Ford Explorer Forums
astrochimp
grand rapids, mi
98 xlt
The owners manual says to look on tape on computer module.
Since we bought the car used, I don't know what the keypad code is for the door.
1998 xlt
v6sohc
:monkey:
mine was located in the back where the jack is located if you take a flashlight and look back in the hole you willsee a module with numbers on it and that is your code
On my '99, the unit is located in the drivers rear compartment where the jack is located.
Good luck.....
yup in the rear fender area on the left side, under all the trim/paneling, accessing will be easiest through the jack stowage area...... you may have to play with the box a bit, but it is writtin on there somewhere
THAT"S where it was..
:thumbsup:
Thanks,
What's weird is that the door code is our HOME ADDRESS..plus 1 digit
:eek:
whats key pad code?
We are in Australia and have no idea what the cassette or key pad code is or used for. The information is not as easily available here.. An explanation would be greatly appreciated
The keypad is the control for the keyless entry system.
thanks:D
