Ya, sorry, for some reason my hosting company is down right now. If you want them directly, I can E-Mail them to you directly. Otherwise, they should be up in a little while (hosting companies ISP is supposed to be fixing the problem).
Or, if you want to use that other link to find it, its a little misleading. When looking in the location that the other directions point to, you can't directly see the hose. There's a silver fuel line when you look in that location, the PCV hose/valve is hiding behind that fuel line. You can't really see it, but if you reach behind it you will feel it. Just pull it up and it should slide right out, if it doesn't you've got the wrong one. Ohh, also, its actually mounted in the top side of the lower intake manifold (a lot of people say its in between the Upper Intake and the firewall which is kind of confusing).
Hope that helps.
