is it in the Power Distribution Box? there is something under the air cleaner related to heater blower, just dont rememebr what, ill consult haynes manual and let ya know if there is anything in there about it
Haynes Manual says: "Locate the blower motor relay, in the relay box behind the right headlight. there are four pins on the connector. Check for resistance between the pink/white wire terminal in the connector, and the pink/white wire at the blower motor. if the resistnace is correct (less than 5 ohms) and the blower doesnt operate, replace the blower relay"
hope this helps, whats wrong does your blower motor not work at all or just on high?
