BonesDT
- July 12, 2002
- Westchester, NY
- Red '99 Sport SOHC 4x4
MIG welding in new cab corners & rocker panels. Where are the ideal places to make my cuts?
For the cab corner, I have the choice of cutting right on the bend or on the flat part. Stacey David once taught me that you should avoid MIG welding on a flat visible body panel as it will show through the paint in the sun (something scientific about different expansion rates).
For the rocker panel, should I cut right down the middle of the nice flat sill, or should I cut on a bend? I could also use the whole height of the rocker panel which would save me a lot of welding, but I know you are supposed to avoid using more replacement panel than you need. Also the very top flange of the rocker panel is a little off from OEM.
Also, there is an overlap between the replacement cab corner & rocker. Where's the best place to join these?
Thanks
Thanks
