Where to get a replacement stock fog light | Ford Explorer Forums
palmaceae
NW Iowa
2001 Sport Trac
Hello all,
My drivers side fog light glass broke today so I am looking for a replacement assembly. It is a 2001 Sport Trac, where can I find one?
Thanks,
as a loyal explorerforums supporter???? I should say check with the site sponsers.
check on ebay also, should be able to get a set for $50.
I ended up making lexan covers for mine since they get hit by little rocks a lot
Thanks,
I found some on Rock Auto, but there are 2 different kind, one is the whole assembly and the other looks like like just the lens and reflector? Are they easy to replace?
Thanks
Thanks,
Thanks
spend the extra $2 and get the complete assemblies, probaby easier to change.
otherwise, you will need to pull the housings, break out the old glass, clean old silicone rubber, glue in new glass, and clip in the reflectors (a lot more work to save $2)
