Jackler
- November 30, 2011
- st. paul, mn
- 1997 ford explorer EB
Hello, and thanks in advance for any help. I have found many answers to many questions on this site, unfortuantely I need a few more.
I have a 1997 Eplorer EB AWD, 5.0 ltr V8 with a 4R70W transmission. Here are my issues; I changed the oil about 500 miles ago, while chatting with the parts guy he suggested Seafoam treatment. Never using these products before, I asked the best way to use it and he suggested in the crankcase. So, I shorted the oil 1/2 quart and added a can of Seafoam buttoned everything up and drove away. 2 days later the car began to run very rough, rough idle, poor acceleration, poor starting and a smell of "burning plastic" in the cabin. Not sure if this is related or simply a bad coincedence.
I took it to the local Pep Boys and had them read the codes and received the following;
P0153 Bank 2/Sensor 1 Slow (O2 sensor I beleive)
P0174 Lean Bank 2
P0175 Lean Bank 2
P0305 (misfire)
P0306 (misfire)
P0307 (misfire)
P0455 Big Leak Evap.
P1152 Switch indicates rich
I replaced the plugs hoping to find some fouled (plugs and wires have 2000 miles on them), plugs in 1-4 looked good, 6 and 7 were oiley and smelled of fuel.
Looking around I also found that the spark plug wire boot on the #6 cylinder has a cut in it, the new plugs did help with startup, but there is still poor idle and what feels like a misfire. There is also the infamous "ticking" sound from the passanger side exhaust manifold (gasket or manifold). And lastly, there seems to be a leak in the gasoline "fill" tube, the tube that runs horizontal from the fill inlet before it heads south to the tank.
I know there are a littany of issues here, what I am asking is where to start? I do not have the funds to fix all of these problems right now, and there is an underlying transmission issue (P0782 2-3 shift) that needs to be addressed. Do any of you see a path that I should take, as in what should be done first, second, etc...
I plan to do as much myself as possible, so any help would be great.
P0174 Lean Bank 2
P0175 Lean Bank 2
P0305 (misfire)
P0306 (misfire)
P0307 (misfire)
