Where was your Explorer built? | Ford Explorer Forums
King of So Cal
So Cal
My 06 was built in Hazelwood, Missouri/St. Louis Assembly. However the factory was shut down in 2006. So I'm trying to figure out where the rest of the 4th Gens where built. Looks like they were built in Louisville or down in Venezuela. But I just want to find out from you guys. So where was your truck built?
If you don't know look at the vin on your truck. It's the 11th digit out of 17. It will be a letter, not a number. Match the letter to the link.
http://en.wikipedia.org/wiki/List_of_Ford_factories
Be interesting to hear!
Louisville, KY
Sent from my iPhone using Forum Runner
I've only ever had St. Louis Explorers. All 3 have been so far!
U
Louisville, KY
Mine is a U also.
Ken.
Mine was Louisville, KY
Louisville, KY.
If you look on your original window sticker (available on this forum) at the bottom you will see "Final Assembly Point" which means components may have been built in other places and it was all screwed together in Louisville.
KY built. mine is an 07
Louisville, KY.
If you guys PM your vin Number (remember, in PM, dont want that stuff published) along with email address, ill post on this thread your Vehicles exact build date, as well as any past warranty info that has been done to it, and will email yall a pdf. Im trying something here and wanna see the interest in it...
Z (NA)
St. Louis Assembly
Hazelwood, Missouri
mine is a 2006 Mountaineer
Thank you Nice59
Prod Date: 12-OCT-2005
Plant: AV - ST. LOUIS PLANT BUILD
Arrival Date: 15-NOV-2005
Sale Date: 19-NOV-2005
Warranty Start 19-NOV-2005
Date:
Orig Warranty 19-NOV-2005
Date:
Selling Dealer: 314453-*
Selling Dlr NY
Engine: T/W8 - 4.6L 3V V8
Transmission: T/VV - 6 SPD AUTO TRANS (6R60)
Air Conditioning: T/G - DUAL ZONE AUTO TEMP
CONTROL AC
Alternator Amp *
Rating:
Audio Disk: * - [N/A]
Axle Ratio: EGAHD - 3.55 FINAL DRIVE RATIO
Axle Type: EGJAB - NON-LIMITED SLIP REAR
AXLE
Battery Amp MR
Rating:
Brake Code: FBAAH - POWR 4-WHEEL DISC
VACUUM BOOST
Brake Code * - [N/A]
(Service):
Calibration Code: 6U51A50A
Color (Accent): * - [N/A]
Color (Trim): 000C4 - CAMEL
Delivery Type: R
Driveshaft Code: *
Front Seat: T/B - SEAT-INDIVIDUAL-L/B
DRV/PASS
Fuel Type: AF - UNLEADED FUEL CAPABILITY
GVW Code:
GVW Class Code: E
Instrumentation: * - [N/A]
Mirror(Driver
Side):
Mirror(Psngr
Side):
Paint:
Power Antenna: AB - FIXED RADIO ANTENNA-
BRIGHT
Radio: A7 - AM/FM STR/6CD/NAVIG SYS
Sound System: AE - AUDIOPHILE SOUND SYSTEM
Suspn Tandem
Axle:
Tire Brand: AJ -
Tire Size: D3HCR - P235/65R18 A/S BSW
Traction Control: AH - ROLL STABILITY CNTRL (RSC)
BRK
Wheel Base:
DL - D PWR PD LMP/HTD/SAT AL
SK CAP
DL - P PWR PD LMP/HTD/SAT AL
SK CAP
PNUAA - EBONY SOLID C/C
