which is better spare wheel? | Ford Explorer Forums
ckomai
Long Beach,CA
1991 Explorer
Right now I have my spare mounted on a 15" steel wheel that is obviously for a spare tire. You can pick up a stock wheel on ebay for 30-50 bucks. So my questions are:
How much weight would be saved from the steel to aluminum wheel?
If I had to run a long distance on the spare (offroad) would the stock wheel be much better than the steel wheel?
As long as the steel rim as well as the spare tire are in good shape it should not matter.
I wouldn't bother unless you want a same rim spare for looks.. Even when I had 31's I used the stock steel rim with a 31" on it. Barley fit under the X, but it fit. Used it a few times, no issues.
