Which Speedo gear for tranny? | Ford Explorer Forums
EMStaxi
Piscataway, NJ
'97 Mountaineer
Ok here's the deal, I figured out that I have a 19 tooth gear and I need a 17 tooth gear. Here is the question, my original is pink but according to this chart I found or The Ranger Station.Com shows this...(I have the Auto Tranny)
Manual Transmissions:
16-teeth-wine(C0DZ-A)
17-teeth-white(C3DZ-C) -----What I need?
18-teeth-yellow(C0DD-B)
19-teeth-pink(C0DZ-B) ------Current gear that I have
20-teeth-black(C1DZ-A)
21-teeth-red(C4OZ-A)
Auto Transmissions:
16-teeth-blue(D0AZ-A)
17-teeth-green(C7SZ-A)-----Or this?
18-teeth-gray(C7SZ-B)
19-teeth-tan(C7VY-A)
20-teeth-orangeC8SZ-B)
21-teeth-purple(D0OZ-B
i also need a new gear to make mine back to normal cause i am running 32's now. keep me posted.
Auto Transmissions:
You want the white one. I ran into this about 6 months ago using the same chart. I pulled mine out and brought it with me. My 5-speed automatic had a black gear 20 tooth gear and I needed a 19 tooth gear. They brought me out the tan one and it was noticeably longer than mine was. On a hunch, I asked them to bring me the pink one and it matched right up and fit perfectly. If yours is pink then get the white one.
The charts on the ranger station account for 2 wheel drive trucks w/ auto and manual trannies. I figured out that if you have 4 wheel drive, use the manual tranny chart when you have a manual or auto tranny. The auto tranny chart only works for 2 wheel drive explorers.
Kevin is absolutly correct on this. Use the Manual chart.
