white on spark plugs | Ford Explorer Forums
DeagleDave
Mount Dora, FL
'92 XLT
when i was taking out my plugs the other day to regap them i noticed that the tips were white. I have heard that means it is running lean. How do i correct that?
Check the O2 sensors or for a vacuum leak.
If I'm not mistaken, a white electrode can also be caused by water / coolant in the combustion chamber.
would water/coolant cause the color change in exhaust? currently i don't blow any visible smoke through my exhaust pipes.
You could be burning coolant, but not enough to produce smoke/steam. Coolant comes out as white smoke. Does your coolant level go down?
not so far
