who had Brown wire mod issues. figured out 2low, now can't get back in 4 | Ford Explorer Forums
challlen
FL
95 4dr 4x4 5speed
i have a 95, with those of you who are familiar with the brown wire mod. The year truck i have i should be able to achieve 2low and 4high using a special switch i have ordered and probably have wired wrong. i believe it is a dpdt on off on switch. if anyone knows the diagram would be appreciated. the sticky doesn't help on this issue. i had normal operation the whole day but when trying to use 2low i somehow found it and then had trouble getting back in 4 anything. I'm thinking issue with transfer case clutch coil. who has this mod done??
