ornithology
- January 20, 2009
- Vancouver, BC
- '03 X Sport2dr 4.0 V6 XLT
Interestingly enough, I find it entertaining reading through all the "magical" ways of increasing your mpg. Recently, while searching through craigslist, I found this guy advertising a "Fuel saving device". What do you know, I was in there browsing and reading what this thing is...well...it sounds very interesting. Here you guys go.
http://www.gofitch.com/
This is what the website states:
The Fitch Fuel Catalyst transforms gasoline and diesel into a superior quality of fuel, allowing a combustion engine to extract the maximum amount of energy with minimal emissions. Get more Performance out of your engines for less: less money, less pollution and less maintenance headaches.
The Fitch Fuel Catalyst is a patented poly metallic alloy that reformulates fuel on board a vehicle prior to combustion. Placed in the fuel tank or housed in a canister and connected into an engines fuel system between the fuel tank and the engine, the molecular structure of fuel is modified by the catalyst alloy to a state where it is capable of more complete combustion. As a result the engine converts the chemical energy in the fuel to mechanical energy in a more efficient and complete manner. The engine power is increased and toxic emissions per unit of fuel are decreased.
An engine operates most efficiently and produces maximum horsepower and torque when it is running on the highest quality fuel. Gasoline and diesel is at its most optimal quality when it is first refined but unfortunately during storage and transportation, the fuel quality drastically diminishes. Sacrificed horsepower, torque and efficiency may be the result of this poorer fuel quality. A less than optimal fuel will also produce more emissions, soot build up, and deposits in engine oil and injectors. The Fitch Fuel Catalyst will boost octane in gasoline, increase cetane in diesel and re-refine the fuel quality, returning it to a superior "refinery" fresh state guaranteeing maximum performance and efficiency from the engine. Unlike additives that require replenishing, the Fitch Fuel Catalyst is warranted for 250,000 miles and does not dissolve or loose its potency.
