Why?! 1st Kelyless entry now power windows | Ford Explorer Forums
soundndfury
Cincinnati,OH
Sorry if this is the wrong forum for this question. I was scrolling through and saw mostly how-to's but the description fits my needs. So here it is: I was dumb enough to follow some bad advice and cut all the wires on one of the plugs that go into the factory alarm/keyless entry module in the back on the driver-side. ( I was told it was the factory amp by Best Buy.) So I would like to rewire the plug, but the local auto-parts store doesn't carry pins (or whatever they're called that are in the plug that clamp onto the ends of the wires) that fit the plug. So where could I get these things and what exactly should I be asking for. Also, just because this truck loves me so much, the windows started acting up. First the rear passenger side window rolled down and not back up (on a cold rainy night). Once this happened the front passenger and rear driver side switch stop working on their respective windows, but the driver door switches work fine for all but the stuck half down rear passenger side window. Figure there must be some stupid @$$ wiring problem here and was wondering if anyone could point me in the right direction. Thanks
The windows sounds like the master switch, they sometimes are just dirty, inside. Finding another would be best, keep that as a spare.
The factory wiring is fairly unique, the maker of those doesn't sell directly to anyone but the car makers. I would suggest finding the whole plug connector and attaching the wires back together. That or cut one from another truck to do that. Good luck,
Thanks
THANK YOU! that will save so much time. One trip to the junk yard could be answer to all my problems! I was totally lost. Thank you!:thumbsup:
