ttbit
- June 24, 2004
- Maryville,TN
- '01 ST 5.0 sold
'07 ST8
OK...this really should be simple....but... I am working on my 5.0 conversion on the 2001 ST and the 2001 starter harness has 2 large wires going to the starter, and maybe a 3rd smaller one. Doesn't the '96 starter only need one from the starter relay? It appears that the 2001 has a relay in the fuse box, where the '96 had one on the inner fender.
Do I need to install a fender relay also? Maybe the fuse box relay won't handle the current draw? On my 2001 wiring diagram, it appears that one wire goes right from the battery to the starter and then the second to the relay.
Maybe I am making too much out of this, but would like to use an existing harness, if I can, but of course, the wires are too short anyway as the starter is on the opposite side on a 5.0. If not, I will buy a new battery cable and wire it like a '96.
Two things I did not grab from my donor vehicle...starter wiring and alternator wiring... Either I didn't grab them, or I lost them in one of my two home moves this year.
Thanks,
Don
Thanks,
Don
