WHY are there different sections for 02-05 and 06-up? | Ford Explorer Forums
JoeCool6972
where ever I may roam...
2007 Sport Trac XLT
Why are there two sections for the 2002-2005 and 2006-up models? They are pretty much the same vehicle with only minor changes.
engine, tranny, tansfer case i believe is different, different front end, interior thats about it that i can think of
likely because they are different generations as well
different V8, different trans on V8, different interior, different electronics, different front/rear end, different std/opt features, etc.
Same reason the 91-94 and 95-01 have diff forums. Just because they look the same for the most part doesn't mean they are.
Nah, it's because Rick rules. This is not a democracy. We give him money and he lets us have avatars. :D
They are quite a bit different though...
crawl under the rear of a 02-05 then crawl under the rear of an 06+.... major suspension changes
Diff gen diff sections
Posted via Mobile Device
lololololol golden rule? man with the gold, makes the rules? ^.^ nah im just messin, its because there are actualy quite a lot of changes with the new generation's, plus...its a different generation!
What has been changed? The rear of our 07 looks identical to the 02 we had before it.
Different A-arm mounts, as well as shock mounts...my dads gen 4 is radicaly different than my gen3.
I work on Fords all day for a living, and I don't see all the radical differences you people speak of. :rolleyes:
It's a different generation so it gets a different part of the forum.
3rd gen... 4th gen... who cares if they are seperated ???
having them seperated = less search times for info your looking for...
ie - why should i have to look through 06' info to find out something about an 03' ??
also... CAUSE RICK SAID SO !!... hahahahaha sounds like the " ROCK " almost lol !!!
Isn't the interior on the 06+ a major switch from the 02-05?
Very much so. I don't think there is anything the same aside from the headliner and upper pillar plastic.
DATC unit is the same iirc.
