- September 1, 2002
- Lake View Terrace, CA
- '91 Navajo '99 X '19 Rngr
Now I have try the engine, though I seriously doubt that will work cause of the pats system.
Originally posted by RobertF
This is why when you buy a used vehicle you have it rekeyed by a professional locksmith. Between sloppy 10year old locks and god knows how many of his friends had keys.... it's a good ideaI also like to get a new set of plates in case someone had it out for him
I had a Toyota P/U that had a key so worn down that you could do that. . i decided to go get a new key since I was afraid I'd leave the ACC or Ignition on one time and drain the batteryOriginally posted by springtensi0n
while driving i can take my key out of the ignition. only one way though. when i flip it upside down, it doesnt pull out. if i wanted to, i could start it with out a key =/ just dont turn it all the way when you shut it off. my friends 89 caddie is the same way...
Yes, but if the key DOES turn the ignition, you could reprogram the PATS system to accept both keysOriginally posted by Stic-o
