Frey7190
- August 17, 2008
- SoCal
- '93 Eddie Bauer
So I took apart my X, because I seemed to have been burning coolant and my valve cover gaskets were dripping oil onto the manifolds, causing me to burn and have smoke coming from my engine compartment. So I went all the way down to the heads, and noticed something odd!
-- First off a little background, this explorer only has 91k on it. The engine was rebuilt from bare bones in 2002 when it had 65k on it, due to some mechanic throwing junk into the engine and causing my valves and components to break and blah blah blah. Then in 2008 when the car had 80k on it, it started to buck at stops, had a real rough idle, and had no power. Took it to the shop and they said my fuel injectors were bad... $1500 later, I had new injectors and still a rough idle.. there follow up to that... I needed new spark plugs... Got new plugs and injectors, and the car drove fine until now..
My parents weren't really in the mood to spend another grand fixing this car which isn't driven everyday, its mainly our utility/back up car. With that being said, my parents were just going to park this thing on the street and just let it sit with this problem... Not ok with me because I love this explorer.. It was my first car, and it holds a bit of sentimental value to me, so I took it upon myself to rebuild it (which im in the process of doing).
-- Back to the main point, when I took the rocker arms off I notice this odd thing, the exhaust rockers were all indented from the exhaust valves! The intake rockers were all fine. So I looked at my cylinder block and noticed that the exhaust valves sit differently then the intake ones! Is this normal?? (See pics below for further explanation)
All comments, responses, questions, welcome!
Thanks,
James
Pictures:
Thanks,
James
Pictures:
