Will 31"s fit? | Ford Explorer Forums
Will 31"s fit?
Just Startin
Marianna, FL
'95 XLT
Will 31" Trxus All Terrains fit on a '95 XLT with no lift?
are you a limited or an EB, if so, look forward to some trimming, if not, a torsion twist and u should be fine
They may a bit, but under full compression very badly. at least my 30's on a 2nd gen did before the shackles. Every truck is different, and I suspect the dealer dropped my tortion bars a bit pre-sale to level with the rear. It was just to low even for a X. You should go the 31 and if they rub lift rather than trim
