southerlin55
- April 1, 2009
- castle rock, colorado
- 1993 XLT
I have a 93 Ford explorer XLT, 5speed, 4x4, with 30x9.50r15 on it. I live in colorado and i often go to the mountains (11,990 FT). The drive up is killing me i cant seem to get my exploder to keep a constant speed without having to rap it out (im always in 3-4 gear between 3.5-4 thousand RPM) and i can never seem to pull overdrive even on the somewhat flat part. Even rapping it out i still struggle to go the speed limit!
I have herd alot about how changing the gears helps with bigger tires but will it do the same without the big tires and help gain power? The speed limit going to the ski area is 65 mph the whole way so i would like to be able to pull that maybe even more if possible.
I also pull a 2 rail motorcycle trailer (loaded is about 450-500 lbs) very often so if gears would help i would need something were this is still possible!
Any help is appreciated!
Thanks
Tyler
Thanks
Tyler
