will recall smooth out idle at all? | Ford Explorer Forums
BajaXplorer
San Marcos, CA
2002 XLT 2WD
Im going in tommorow to leave the X at the dealer for the 01m01? Cam Tensioers recall.
Does anyone think this will smooth out the idle a bit or?
I get a bit of surging I notice when stopped at a light. It so minute , that the tach doesnt even move , but you feel it.
I doubt it but just a thought?
Im planning on going with new plugs, wires and cleaning the TB, and MAF.
1 at a time to see if it makes a diffrence. Luckily a friend has an OBD-II scanner to check the codes and see if shows anything.
Thanks,
Doug
if it works...
I dunno if it will work, you have an SOHC? Mine is a OHV and i have the same rough idle which just started. Its my understanding that the recall is for SOHC and has nothing to do with the OHV. PLEASE CORRECT ME IF I AM WRONG!!
recall
No that is another TSB! Under exhausts. What’s happening is the exhaust is resonating and in turn causing the shake
Hope this helps!
