huntman58
- February 13, 2007
- Fremont calif.
- 2013 Dodge Advenger
Okay see if rewording this will help.
I have a 93 XLT 4 door and I can not set a base idle on it at all nor make it slow down when unplugging the AIC! (I even made a gasget to block it off fully with no change.)
With AIC unplugged TP stop screw out and not touching the stop the truck idles at 850 to 920 RPMS.
Plug in the AIC and it jumps up about 1500 RPMs then comes back down to the same 850 to 920 RPMs in P or N.
If you put it in gear R or D it drops to about 750 RPMs it’s a bit ruff and or vibrating.
Turn the A/C on with it in R or D and it drops to 550 to 600 RPMs and very smooth.
MAFs cleaned and computer has been reset many times
Vac lines all check out so one would tend to believe an intake leak. I can not find it using WD 40, propane, carb cleaner or TB cleaner.
Is it more likely to be the
Upper intake gasket?
The one below the fuel rail?
Or the intake on the very bottom next to the heads?
It has a very slight miss also that seams to move around.
KOEO is all pass and KOER I get 411 and 412 can not control RPM normaly from to high of an idle. I have also gotten on and off O2 always lean for both banks. they show together or they are both gone never only one showing that also leads me to think intake leak before injectors.
It is not using any antifreeze so do not think it’s the heads at all.
I do not have much money to throw at it so I want to do it right the first time .I know if I go below the fuel rail I do plan to change the injectors also .
As a side note any one notice the dash TAC off by about 250 to 300 RPMs besides my self?
