Will these wheels fit? | Ford Explorer Forums
Sigpros
02 sport trac
Will a set of factory 18" wheels off a 2014 explorer fit on my 2002 sport trac?
Found a set for the same price as new tires and they look a lot better.
Thanks for any help
They both have a 5x4.5 bolt pattern, but the '14 offset is 40mm vs your '01's 30mm. I believe this would push them out a little wider, but hopefully someone with better wheel knowledge can chime in on the offset difference.
Thank you. I don't understand this wheel stuff very good
