Carguy3J
- June 21, 2008
- North East New Jersey
- '99 4dr. XLT SOHC A4WD
I have a '93 Ranger 4.0L, 5spd, 4x4.
I just picked up a never-run rebuilt motor. It has a 410 comp cam, Accel 24Lb/hr injectors, and some mild gasket matching port work on the intake manifold. I was told the heads got a 3 angle valve job, along with some mild port work/bowl blending. Otherwise, the motor is all stock replacement parts.
I know the 410 cam is supposed to be a considered a stock replacement cam, and should run fine with a stock ecm. What about those 24LB. injectors though ( stock is 19Lb, right? )?
I asked the seller, and he said that comp told him that the injectors would just make up for the extra airflow of the cam, and would still run right on the stock ecm. Opinions on this?
I know that a tune is always helpful, but is it required, with these parts? A tune just isn't in the budget right now. I guess I could swap in my stock 19Lb injectors, but I'd rather not.
Also, the seller built the motor with stock replacement valve springs, rockers, and pushrods. Will these be ok, with the comp 410?
