Windows wont work | Ford Explorer Forums
Windows wont work
jdolan5
1997 explorer
I just bought a 97 Explorer and none of the windows work. They do not do anything, like there isn't any power to them. Does anyone know what fuse or relay I would need to check to see if that is the problem?
If the fuse is good,check the wire harness that runs between the drivers side door and body of the truck. If there's a frayed or a broken wire in there, repair it and it should resolve the issue for you.
Hope this helps you out,
Tony
