Windscreen washer | Ford Explorer Forums
Windscreen washer
TR
uk
00Northface
Front and rear washers not working. Motor doesnt run when switches operated. 12vdc is measured at the plug when the switches are operated. I have removed the pump and connected to a 12vdc source and motor/pump runs! Any assistance, suggestions welcomed.
Check your fuses mate, as you have power in the test you did, I think the power is not getting past the fuse box. Let me know how you get on.
