[QUOTE='97 V8]I have yet to find decent blades. I had dupont and had to replace them after 6 months. The Bosh blades have been on for a year, but 4 months of those they have sucked. They smear and make things very glarey at night. Now im on the cheap $6 blades from autozone. Im now using rain-x as well.[/QUOTE]
Try this. I've heard it works.
http://kalecoauto.com/index.php?main_page=product_info&products_id=23
Which Bosch blades are they? If they're the rubber ones, then yes, they last longer than most, but still nowhere near as long as the Silicone blades. If they are the Bosch Silicones, then try a couple of things.
(These are my window-cleaning secrets. Some may scoff at the use of newspaper, but believe me, it works. You must use the black and white section, not the color pages... I don't know why, but the colored ink leaves streaks, while the black and white doesn't)
First, take some windex and a piece of coarse paper towel (even a brown paper bag works, but I usually use the brown paper towels at the gas pumps) and gently scrub the edges of the blades. You'll get a layer of crud that builds up there that plain ol' car wash soap doesn't take off. Even a little bit of alcohol will work.
Second, scrub the glass with dawn dish soap and water to remove any oily film that may have been sprayed on teh window. Diesel fuel, oil, and antifreeze can work their way from the road to the window during the rain, and WOW what a mess they make. Scrub the window down with a fairly stiff sponge and the soapy water, towel dry, then use windex and plain black and white newspaper to windex the glass. Spray the glass, scrub it with the newspaper (which should be a little bit soggy itself, leaving the glass streaky) then use a dry piece of crumpled newspaper to buff it dry. (Repeat to the inside of the glass)
Finally, once it's sparkling clean, apply some rain-x to the exterior surface. Refill the washer fluid with Rain-X solvent (summer or winter formula as necessary) and you can literally go YEARS without reapplying the rain-x to the windshield! (I haven't done the Explorer in 4 years, just to see how long I can go!)
-Joe
