dersch6221992
- June 16, 2009
- Indiana
- 2000 mounty
So today i finally put my offroad lights back on my truck. i this time wired them into the fog lamps tho. What i did was run a seperate ground from each offroad lights and then spliced the hot into the fog lamps. ran each offroad light right to fog lamp right vica versa. it worked great and it lit up. but not the problem is. i went to class tonight didn;t use them at all and when i turned my lights on after class they didn;t work only the headlights worked. so now my next thing is.... do i add a bigger fuse? i guess fuse #8 is the one for the fog lamps. im thinking bump it up a few amps and it should work? That or can i run the grounds to the fog lamps and the hot straight to the battery and solve the problem?
Any insight/ help/ personal expierence would be GREAT.
Thank you.
Thank you.
