WTH is this noise. . . | Ford Explorer Forums
Strike_Zero
Irmo, SC
94 XLT
http://www.youtube.com/watch?v=dCInIM9ARG8
Wifey's exploder issues. Have you ever heard such a NOISE??? Shiiiieeee. . . . Replaced water pump, belt tensioner, p/s pump, idler puller and belt. I'm guessing it I need realign the accessory brackets better??? Any suggestions?
Going by the whirring noise with the squeaking, I am going to say power steering pulley/pump.
take your belt off and spin all your pulleys , see if they spin freely, IF they do change belt tensioner... I had to replace the tensioner on my Ranger last winter, same noise
Thanks for the tips!! I spun them all by hand once I replaced everything. I'll pull the belt in the morning and check again.
The P/S pump had resistance, but I was thinking it was like that based on the fact it has fluid in it.
One thing I forgot to mention (can't remember if I shot it in the video); if AC compressor cycles and squeaking almost goes away completely.
Also after replacing the water pump, there was no squeaking until about 5 minutes of it running to circulate the coolant
Robrt32 - I put on the a new belt tensioner when did all the other work.
Thanks for the suggestions thus far!! Looks like I have some good leads for in the morning. . .
I know you can try to put a bar of soap on the belt and sometimes that works. It did that for me sometimes with my 94'
Think I found the problem . . .
Belt slip at the P/S pulley :mad:
I sprayed some water on the P/S pulley while it was running and squeaking went away. . . .
I pulled the belt it is ate the **** up . . . Duralast piece of crap . . .
Off to get a Gatorback.
How long ago did you replace the belt?
Regardless of who made it, it should last a good few years. If it's fairly new, I'm thinking you might have another issue causing the belt to go bad, and the same thing will happen to a Gatorback.
Mike
Mike:
The belt was done back in Feb, I think. I replaced before I did the P/S. I replaced the pump and used the pulley from the toasted/leaky one. It started screaming pretty bad
I cleaned the P/S pulley pretty good. I just put the gatorback belt on and all appears to be fine. If it starts squeaking again, I'll replace the pulley . . . Now off to do front wheel bearings . . .
Got me to laughing over here......SHIIIIEEEEEEE hahahahahaha, excellent description though, but comical as hell.
I'd go for belt tensioner or alternator pulley. Mine used to do that until I replaced both. Didn't think to replace one to see if the other was culprit.
Idler Pulley and/or Tensioner Pulley. They can be re-greased to save them. But their replacement is cheap enough.
Ryan
