VDub2625
- May 28, 2006
- Fall River, MA
- '97 Explorer Sport
Hey all. I bought my '97 Explorer Sport back in June for a good price. It came with an engine rebuild (60k miles so far), and a transmission in it's golden years (170k, no rebuild that I know of).
First off, should I have the 5 speed auto? I have the SOHC V6 with 4wd. Second, after I bought it, the O/D light started flashing. I asked here what that could be, but I didn't get a definite answer, and the slippage at 50-ish MPH was increasing badly so i just figured it was on it's way out, so i waited for it to die. Sure enough, after a clunk and a marbles-like sound, I was immobile. It ecentually "caught" and I could move around again, but it is sure enough dead. I jsut read this though:
I don't know much about automatics, but with what i do know about cars, it sounds like it died. Or did it? Can I replace the valve body as indicated above? Is this a good time to find a replacement trans or a rebuilt trans (cash depending)? Thanks!
Oh, one more question, though i know the answer: what about a 5 speed manual swap?
Q1. My 4R/5R is starting to display an OD light that is flashing, and the shifts are sometimes late, or "soft".
A1. These transmissions use an electronic pressure control (regulator) solenoid (EPC) that works hard to maintain a contant pressure as commanded by the computer. It seems these have a useful life of 65,000 miles on the low side and about 150,000 miles on the high side. In addition, these transmissions were prone to blowing out main control (valve body) gaskets. FORD came out with a technical service bulletin (tsb) on these issues and there is a kit that modifies the VB and changes the separator plate and gaskets. I recommend whenever there is this issue to change out the EPC. It costs about $115. The FORD mods are about $30. This is a good time to upgrade the Valve body too. (See separate Q on this below).
