Yet Another P0171/P0174 Problem | Ford Explorer Forums
natecrep
SoCal
2001 Sport Trac 2wd
I'm going nuts with this one. I know of and have read all the threads on this issue with no luck. When this problem first started I had plenty of time, it's now taken me so long it's become very urgent for me because I work on base with the military but can no longer drive on base due to registration just expired because I can’t pass smog thanks to these codes. Smog test results are all perfect for emissions by the way - it fails the functional check (seeing the codes).
The truck runs fine, idles fine, no hesitation or misfiring. When I reset the codes it takes between 15 and 25 miles before they come back. First I tried sprays to isolate a leak - no luck. I read out all the sensors voltages and checked their operation as best I could. Have now gone as far as removing all the hoses and elbows and checking them individually with a vac pump. Took it to a shop for a $120 diagnostic check, they said they did a smoke check and found the intake manifold gasket to be leaking. They wanted $700 to replace!
So I brought it home and replaced it myself only to have the codes return 20 miles later. Assuming the problem has to be common to both banks I now checked the fuel pressure. With no filter installed I get about 32-34lbs at idle - my book says it should be between 30 and 65. I'd feel better if it were say 45 or 50 but since it barely makes it past 30 - does anyone think that may be the issue? It's too expensive a guess for me.
Any suggestions would be appreciated - if I can afford it I'll try it.
Thanks to you all.
Tom
which intake gaskets did you change, you need to change both upper and lower.
Hi,
Thanks for your reply. I have the one piece manifold so there is only lower. Checked to see if it was warped with a straight edge also - looked fine, also replaced all 8 bolts while it was off. Didn't help!
Aloha,
sure did - specifically payed close attention to this one due to the thread and it's good. Driving me nuts! Thanks for your help though.
Tom
that low of fuel pressure at idle means it will be low during acceleration too there by leaning out the motor causing codes. fuel filter to start then if that dont fix it you might be doing a pump
mine was a gasket on the EGR valve....did you check your egr valve??
