Nitrous SSC said:
I saw stadX2's route and I would think things could be simpler. He completly converts it over to the Control-trac and I personaly don't want that.
I'd like to keep it extremely simple with minimal wiring. Isn't there a way to simply just make it go 2wd/4wd/4-low. I mean I don't understand why you have to add another computer and change the GEM.
Short answer: Hell ya!
Long answer: StadX2
wanted control trac, and did all the work necessary because the system is VERY nice (when it works properly). The GEM and BW4405 combo allow everything from automatic, on demand, on-pavement AWD, 2wd, 2wd low, 4wd hi, 4wd low. Pretty nice.
This system is availible via two different routes for us V8ers. The first is to do what Stadx2 did, and make the rear of our transmissions like our v6 explorer counterparts with 25spline output shafts and 5bolt tailhousings. Then use the V6's BW4405 t-case. The second route is to try and shoehorn in a BW4406 t-case from an Expedition or Navigator. Identical in operation, but will bolt to the 4R70W without fuss as it has the correct 6bolt/31spline connection. Its HUGE.
The GEM and wiring were swapped to make it all work, since the electronic t-cases are computer controled. If you want a manual, lever operated t-case, no electronics are needed with the exception of transferring your VSS from the old case to the new case.
We've been looking for manual t-cases that will fit in the vehicles without transmission modifications and the expensive AA needed to do so, or much wiring involved. Stay simple, stay reliable. There is no reason (and this would be very clean, very doable) to use the AA adapter, and then a manual, lever operated BW1354 t-case. The BW1354 is essentially a BW4405 without the electronic clutch and shift motor. Its what all the hardcore V6s swap in, without crossmember or driveshaft modifications to
their rigs. If you went this route, you would have to do everything StadX2 did, without the wiring.
The cons of going this route, rather than say the BW1356 out of an 80s fullsize Bronco are:
1) The transmission will need to be removed from the truck.
2) A $500 adapter from AA will need to be installed.
3) The case is theoretically weaker than the fullsize cases, which were designed for V8 applications. In reality, the cases are fine for stock V8s.
Either way, driveshaft lengths will need to altered. So that's not a factor for comparison.
