Zex Nitrous Module Location | Ford Explorer Forums
BrianB31
Belleville,MI
1998 Ford Ranger
Well I've saved my pennies and I'm going to get a Zex Nitrous Wet kit #82023 for my Ranger with the V8. I've done some searching on here and found the old threads for the dry kits but the pictures aren't there anymore.
My first question is to those who used the Zex kits where did you mount your control modules under the hood? My second question is the blowdown tubes. How did you seal them against the floor?
Thanks!
my control module is right where the stock airbox is on the fender. That location give me enough reach for the nozzel into the intake and the purge kit to go to the center of my grille.
I have yet to install my blowdown tube so im not sure abotu the sealing procedure
I have my located on top of the washer tank in front of the blower motor. This kinda hides it but also gives me a good access to inside the truck with the arming switch and such.
thanks, Doug
