Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
WTF? Smoke from steering column, think it's turn signal
Reply
Thread Tools
Old 08-26-2007, 06:17 PM   #1
TheJackal
Mandeville, LA
1999 Explorer XL 2WD
Vehicle Specs
Quoted: 1 Post(s)
(Original Poster)
As I was heading home today, I put on my left side turn signal to signal a turn that I was going to make into an intersection. After a few moments, I stopped hearing the turn signal click. The green arrow was on solid, but dim. My first thought was either a bulb or a flasher, but then suddenly a small stream of white smoke came from the steering column, through the opening for the hazard switch. I turned off the signal quickly and then tried it again a few times. Now, the signal works, but I'm always getting smoke from the column, which I presume is coming from the stalk switch.
It looks like I need to replace the turn signal/wiper/hi beam stalk. Has anyone else had this problem before? What about tips for dismantling the steering column? Thanks in advance.
TheJackal is offline   Reply With Quote
( Join the Elite Explorers )
Old 08-26-2007, 06:20 PM   #2
Turdle
Move along people
nothing to see here
Turdle's Avatar
2000 Mounty
Vehicle Specs
Quoted: 699 Post(s)
The multi ###tion switch is a common problem--
http://www.explorerforum.com/forums/...archid=2026362
__________________
Jon
9 mile skid, on a ten mile ride. Hot as a pistol but cool inside.
2000 Mountaineer
1998 Mountaineer "Turdle"-gone
1993 Convertible "Vitamin D Wagon" Sold also
Turdle is offline   Reply With Quote
Old 08-26-2007, 06:21 PM   #3
TheJackal
Mandeville, LA
Vehicle Specs
Quoted: 1 Post(s)
(Original Poster)
Yeah, sorry, I should have searched first. I thought for sure no one else was having this problem...
Old 08-27-2007, 10:44 AM   #4
Hoppy
Ontario, Canada
2000 XLS 4x4 SOHC
Vehicle Specs
Quoted: 0 Post(s)
Cool
Hmmm, Explorers with smoke signals...Pretty cool!
__________________
1986 Bronco II XLT 4x4
1992 Explorer Sport 4x4
1997 Explorer XL 4x4 (Killed by an impaired driver)
2000 Explorer XLS 4x4
Hoppy is offline   Reply With Quote
Old 08-27-2007, 11:50 AM   #5
mcpherson
Cumming, GA
'98 XLT, '88 YJ
Vehicle Specs
Quoted: 0 Post(s)
Just take it apart and slap some grease in there, fixed my problem.
__________________
Nick, KJ4QIZ
'98 Explorer XLT - mcpherson's Registry
'88 Jeep Wrangler - mcpherson's Build Thread
"If anything can go wrong, it will" - Murphy's Law
mcpherson is offline   Reply With Quote
Old 08-27-2007, 12:31 PM   #6
aldive
Elite In Memoriam
aldive's Avatar
1999 XLT
Vehicle Specs
Quoted: 0 Post(s)
Quote:
I would definately replace the multifunction switch.
__________________
Al Franklin
My truck
My Quest for 30
RIP Al Franklin! 1947-2010. Gone but not forgotten! :(
aldive is offline   Reply With Quote
Old 08-27-2007, 12:57 PM   #7
mcpherson
Cumming, GA
'98 XLT, '88 YJ
Vehicle Specs
Quoted: 0 Post(s)
Arrow
Quote:
Originally Posted by aldive View Post
I would definitely replace the multifunction switch.
The problem i had seen once I took switch assembly apart was that the contacts became dry, and in the result was causing sparks which then made the copper contact hot and would melt the closest item "plastic". I carefully took it all apart, cleaned each contact with cleaner, reassemble and rubbed electrical grease over all the moving parts and any contact service. I have not had a problem with this since and also it was an inexpensive fix.
__________________
Nick, KJ4QIZ
Old 08-27-2007, 01:02 PM   #8
Exploderpilot
Nuevo, CA (where?)
Exploderpilot's Avatar
07 Titan SE
Vehicle Specs
Quoted: 0 Post(s)
i don't want to say you're wrong, Mcpherson, but replacement of anything that smokes sounds reasonable to me!
__________________
Member of IAVA Iraq/Afghanistan Veterans Association
03 ranger (Traded in for 07 Titan)
92 blazer (The one with all the horsepower)
Exploderpilot is offline   Reply With Quote
Old 08-27-2007, 01:07 PM   #9
Hoppy
Ontario, Canada
2000 XLS 4x4 SOHC
Vehicle Specs
Quoted: 0 Post(s)
What about things that are supposed to smoke??
Just kidding. I had a similar issue on my Fathers Windstar a couple of years ago. I regreased it and it was fine again too. I didn't see anything evidently wrong with it though.
__________________
Old 08-27-2007, 01:21 PM   #10
mcpherson
Cumming, GA
'98 XLT, '88 YJ
Vehicle Specs
Quoted: 0 Post(s)
Quote:
I most defiantly agree in with replacing it if it requires it, but there always will be a reason. In this case; for the reason my assembly was smoking was during a turn to the left and also using the turn signal. I used the above method, and all has been good.
But, please this was only a suggestion and a fix to my problem before it would cause an electrical problem.
__________________
Nick, KJ4QIZ
Old 08-27-2007, 03:26 PM   #11
TheJackal
Mandeville, LA
Vehicle Specs
Quoted: 1 Post(s)
(Original Poster)
I've got the new part on order at Advance. It should be here by tomorrow morning.
I thought about taking it apart & greasing the terminals, but I figure it's not really worth the trouble. If it's giving me trouble now, then something else in it will go wrong, then I've got to take the time later to deal with something that wouldn't have been an issue if I just replaced it now. Trust me, I've learned this the hard way before with other things... To me, it's worth nipping future problems in the bud.
BTW, I'll probably keep the old one as a spare & regrease the contacts in case this new one gives me any shit later.
Old 09-14-2007, 06:23 PM   #12
eddie mischief
Sarasota, FL
'96 XRT
Vehicle Specs
Quoted: 0 Post(s)
Exclamation
i do know they have a recall on the cruise control because they catch on fire, hmm be careful.
eddie mischief is offline   Reply With Quote
Old 09-14-2007, 10:19 PM   #13
TheJackal
Mandeville, LA
Vehicle Specs
Quoted: 1 Post(s)
(Original Poster)
Quote:
Yeah, but this wasn't related. The cruise control switch is on the brake cylinder, the MFS/turn signal switch is in the steering column.
Old 09-18-2007, 02:34 PM   #14
jagarundi
Brooklyn,NY
1998 Explorer XLT AWD
Vehicle Specs
Quoted: 0 Post(s)
I get this same symptom also every once in a while. It usually stops after I take my foot off of the brake pedal.
__________________
So...........Now what?
jagarundi is offline   Reply With Quote
Old 12-11-2007, 05:02 PM   #15
fordprobegirl
Northwest CT
94 Sport 5 speed
Vehicle Specs
Quoted: 0 Post(s)
anyone know if this was a problem in the earlier years as well? I have a 94, and the fuse keeps blowing for the turn signal/rear defrost/blower motor. I figure one of those must be causing my issue, and there was a lot of smoke before I shut it off and had it towed home Any suggestions? Oh, and also the idiot who had owned it before me must have also had a problem, because they had replaced the 15 amp fuse with a jump wire.....(yeah.......i have NO COMMENT FOR THAT)
fordprobegirl is offline   Reply With Quote
Old 12-11-2007, 05:26 PM   #16
L4CX
East Lansing, MI
96 XLT
Vehicle Specs
Quoted: 0 Post(s)
Well, If it's doing that, get prepared for a Buzzing/Hissing noise while signaling. Mine does it too. I haven't had the $$ to replace but I know it's more then the contacts because the Windsheild sprayer "button" Won't work very well. Good luck.
__________________
Scott "CasaNova" Keef
ZAPV7 and ZAPB1 (Zombie Attack Preparedness Bus)
United Christian Off Road Alliance
Lifted 4 Christ Truck Club
Proof I have To much to do Already
L4CX is offline   Reply With Quote
Old 12-12-2007, 09:31 AM   #17
05dink05
MARYLAND
99 XLT - 97 EB
Vehicle Specs
Quoted: 0 Post(s)
I had this problem a few years back with my 1999 Ex. It happened a few times, I never did anything about it. ( Well , I took it to the closest dealer the first time, they were clueless.) It hasn't come back.
05dink05 is offline   Reply With Quote
Old 12-13-2007, 02:04 AM   #18
reserved50
Current : 2011 Base Exploder
Last: 97 XLT SC'd 5.0/331
Vehicle Specs
Quoted: 40 Post(s)
I had a bad multifunction switch, my turn signals used to freeze till i opened the switch and performed surgery by cleaning the contacts and re-greasing. I would just buy a new switch, so much easier and safer. I also had a bad wiper motor relay at the same time,... oh yea and add to that the bad blend door rmotor. Then you wish you had bought a 98 up truck . I think I got every gremlin under control now, sometimes I used to think I'm driving a Dodge
reserved50 is online now   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
