ford99_1979
- August 17, 2009
- Calgary, Alberta
- 2020 ST
As things are getting closer and closer thought I would update.
Started late last year, reading posts and asking questions. I decided to go ahead to drop in a built 347 into my 1996 explorer which has over 300,000km (almost 190,000 miles) on it. The truck still runs great BTW, and has been in the family since new and its been in my hands since last Oct.
First impulse was a cheap 1996 complete 1996 5.0L Explorer motor on fleabay. Shipped it to the engine builder to use as a donor.
It is a 347 built by Fordstrokers with a custom cam from Camshaft Innovations.
- Scat rotating assembly
- Mahle pistons
-Trick flow fast as cast 190cc heads
- comp gold rockers
- trick flow Track Heat intake.
- Torque Monster Headers built with the correct exhaust flange.
Other items of note
- 1" phenolic spacer
- 70mm accufab throttle body with modified throttle arm
- 30lb injectors
- 255lbs/hr fuel pump
- re-use the explorer intake elbow 70mm dia.
- black trick flow valve covers
- utilize some of my MAC intake
Supporting items
- 75mm Prom M MAF (Henson Performance)
- Wideband 02 sensor (Henson Performance)
- tuning (Henson)
Other to-do's
- exhaust will be re-done from the headers to cat back with mandrel bent tubing and new cats. Larger mandrel bent intake tubing to match larger diameter of MAF and TB.
This motor is being bolted to a Lentech 4R70W with 2600RPM 11.5" stall converter.
I'd like to thank many people for advice and tips but especially Don - CDW6212R for pointing me in the right direction with Fordstrokers and equally important was providing me with a custom made 28oz balancer with the explorer timing ring machined and pinned on there.
2010man for selling me his 1994 Mustang Cobra OEM crank pulley. This part is not made by ford anymore and has the same diameter of the explorer pulley but bolts to the custom 28oz balancer that Don sent me.
Also Turdle and tmsoko for answering some questions.
here it is at the engine builder
here it is at my shop, patiently waiting. mocked up driver's side header and intake.
Here is a used 70mm accufab throttle body next to a stock explorer 65mm TB. I modified the arm on the TB to match the location of the stock explorer linkage so both the throttle and cruise cables/linkages with match up.
I will post more updates as they come.
- Mahle pistons
- comp gold rockers
Other items of note
- 30lb injectors
Supporting items
- tuning (Henson)
Other to-do's
