Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
Can't lower spare tire.
Reply
Thread Tools
Old 02-06-2012, 11:34 AM   #1
robertoa1a
Jacksonville, FL
96 5.0 xlt 2wd white/char
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Okay, after trying to lower the spare tire as you would on any truck, (with the factory tire iron through the lift gate) I discovered that there is no where to insert the darn thing. There is a hole but nothing in it. It's like something is missing.
Looking inside with a flash light all I can see is a Allen head about a foot deep in there.
I'm lost.
robertoa1a is offline   Reply With Quote
( Join the Elite Explorers )
Old 02-06-2012, 11:37 AM   #2
1996BLKBauer
McHenry, IL
1996BLKBauer's Avatar
1996 Eddie Bauer AWD V8
Vehicle Specs
Quoted: 86 Post(s)
I'm lost.
I know mine takes a little bit of fighting for the tool to finally fit in there. Just keep messing with it, I cannot really see it breaking considering that the spare on most vehicles are barely lowered.
__________________
Martha, My 1996 Ford Explorer Eddie Bauer Edition
-Alpine stereo, with Alpine Type S Doorspeakers and Alpine Type E Subwoofers in a dual chamber sealed box.
-15x7 Cragar Soft 8's, On Goodyear Wrangler Authority 31x10.50x15 Tires
-Midland 1001 LWX, with Firestick 4ft. whips on taillight mounts.
-Torsion Twist, and Warrior Shackles.. Safari Rack, and 6 Hella off road lights.
1996BLKBauer is offline   Reply With Quote
Old 02-06-2012, 12:07 PM   #3
8111870
Oshawa
98 xlt
Vehicle Specs
Quoted: 0 Post(s)
Are you using the right end ?
its the "hook" that goes through.
my winch was completely seized, had to drop it and free it up so it can be used. Now i lower and raise the spare twice a year to keep it from sticking.
8111870 is offline   Reply With Quote
Old 02-06-2012, 12:22 PM   #4
Turdle
Move along people
nothing to see here
Turdle's Avatar
2000 Mounty
Vehicle Specs
Quoted: 688 Post(s)
There should be a slightly hooked "screwdriver" type tip on the end. These often break off and get caught in the winch "tube". If the end of your rod has an open square hole, the tip is probably lodged in the winch. I had to pry mine out and weld the tip back on,
__________________
Jon
9 mile skid, on a ten mile ride. Hot as a pistol but cool inside.
2000 Mountaineer
1998 Mountaineer "Turdle"-gone
1993 Convertible "Vitamin D Wagon" Sold also
Turdle is offline   Reply With Quote
Old 02-06-2012, 12:43 PM   #5
FORD SUV GUY
VERMONT
2000 FORD EXPLORER
Vehicle Specs
Quoted: 0 Post(s)
There is also a plastic funnel looking type guide that helps in aligning the tool into the slot on the winch for lowering and raising the tire. On my "98" Ranger that plastic guide came lose and ended up in a position where it blocked the receiving slot in the winch. I had to crawl under the truck and "fight" the plastic funnel looking peice out. I never had another problem, but it took some head scratching to figure out what was going on initially.... Hope your able to figure it out.
FORD SUV GUY is offline   Reply With Quote
Old 02-06-2012, 11:01 PM   #6
rego
Mn
98xlt,2000xlt both ohv 6
Vehicle Specs
Quoted: 6 Post(s)
Tire iron won't do it. Fold your back seat down and look for what you need under the panels that lift up.
rego is offline   Reply With Quote
Old 02-06-2012, 11:30 PM   #7
swshawaii
Kailua-Oahu, Hawaii
'05 Sport Trac XLS (RWD)
Vehicle Specs
Quoted: 933 Post(s)
Would think he's figured this out, otherwise would have heard back by now.
swshawaii is offline   Reply With Quote
Old 02-08-2012, 03:50 PM   #8
robertoa1a
Jacksonville, FL
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Can't lower spare tire!!!
I'm trying to inspect my charcoal filter above the spare tire.
The trouble is I don't see a place to put the tire iron to lower it.
There is a hole behind the lift gate but when I look in there with a flash light, all a see is a small Alan bolt about a foot deep.
Old 02-08-2012, 03:58 PM   #9
kert0307
Pella, Iowa
'00 Sport and '89 B2
Vehicle Specs
Quoted: 0 Post(s)
Look under the carpet just behind the rear seats, there should be some tools there to "hit the hole"
They look like this
__________________
____________________
89' B2 -Sold
00' Explorer Sport - Sold
05' F250 Crew Cab 4x4 Diesel Clicky tow rig/DD
2011 Ford Edge - Wife's DD
1978 Glastron CVX16 Project Boat
kert0307 is offline   Reply With Quote
Old 02-08-2012, 05:14 PM   #10
jad2411
El Paso, TX
blue 02 xlt & white 02xls
Vehicle Specs
Quoted: 1 Post(s)
You should read the answers on the original thread...
http://www.explorerforum.com/forums/...d.php?t=345150
__________________
If interior is to exterior and
include is to exclude, then
increment is to:
jad2411 is offline   Reply With Quote
Old 02-08-2012, 05:30 PM   #11
buckwill
trona calif
1998 sport
Vehicle Specs
Quoted: 0 Post(s)
if you raise your rear hatch, look just over the bumper just to the right of center there is a hole,, choose the tool ext that has a flat end most like a big screwdriver,, put that end in first, then the other, socket them together and the handle,, it will pretty much guide its way into the spare winch,,lefty loosy,, down,, righty tighty up, in a pinch u can use a regular long jack handle with the flat hubcap end to drive the winch,, just barely reaches,, buck
__________________
if my memory was getting shorter would i know???,, disabled viet vet, retired navy,, 98 exploder sport sohc 4.0,, retired macinist,gas and steam turbine millwright,, ive arrested, stroked twice and i mispell lots,
buckwill is offline   Reply With Quote
Old 02-08-2012, 05:35 PM   #12
Turdle
Move along people
nothing to see here
Turdle's Avatar
2000 Mounty
Vehicle Specs
Quoted: 688 Post(s)
threads merged. One thread per topic please.
__________________
Jon
2000 Mountaineer
Old 02-08-2012, 06:24 PM   #13
swshawaii
Kailua-Oahu, Hawaii
Vehicle Specs
Quoted: 933 Post(s)
Page 299+
http://www.motorcraftservice.com/?li.../96expog1e.pdf
Old 03-23-2012, 06:35 PM   #14
myrtlenjune
1998 ford explorer sport
Vehicle Specs
Quoted: 0 Post(s)
Quote:
They look like this
what if i dont have one of those bars? i just bought the truck and cant find that tool, i have a 1998 ford explorer sport
myrtlenjune is offline   Reply With Quote
Old 03-23-2012, 07:19 PM   #15
jad2411
El Paso, TX
Vehicle Specs
Quoted: 1 Post(s)
go to a jy and buy them I paid 10 bux for mine I think...
__________________
increment is to:
Old 09-16-2012, 01:15 PM   #16
woodbridge548
douglas ga
2001 ford ranger
Vehicle Specs
Quoted: 0 Post(s)
thanks to this site i was able to lower the spare tire on my 2001 ford ranger, i had no idea, how to lower the tire,
woodbridge548 is offline   Reply With Quote
Old 09-16-2012, 01:20 PM   #17
swshawaii
Kailua-Oahu, Hawaii
Vehicle Specs
Quoted: 933 Post(s)
Quote:
Ford 101:
http://www.motorcraftservice.com/?li.../01ranog4e.pdf
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
Spare Tire jonnyslick Stock 2002 - 2005 Explorers 6 10-02-2008 09:37 AM
Who Made Your Tires?----Chart: hermitrl Ford Explorer - Ranger Tires & Wheels 10 01-31-2005 09:00 AM
Spare Tire Size? BonesDT Ford Explorer - Ranger Tires & Wheels 7 11-07-2002 08:08 PM
Spare Tire & Dual Exhaust Problems... RammaR Ford Explorer - Ranger Tires & Wheels 7 10-22-2002 01:28 PM
2" receiver tiltable spare tire carrier for under $120 donkey boy Ford Explorer - Ranger Tires & Wheels 2 02-06-2002 08:38 AM
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
