Naasau
- January 2, 2007
- Denver Colorado
- '93 Explorer XLT
My goal for this registry is not so much to provide a story of how this build has gone/is going, because that would take years... too many years... but rather to provide an aggregate list of the maintenance/repairs/upgrades that I've done over the years as well as what still needs to be done. That way if anyone sees me headed towards a cliff, they can throw out a warning in time, cause god knows I need all the help I can get.
Now for the nitty-gritty:
Interior:
[ ] Add additional gauges:
Fix Oil Pressure Gauge
Temp Gauges
Vacuum Gauge
[ ] Replace Dash Gauges (Make 'em Red!)
[ ] Re-engineer Center Console
Include wiring for cab winch controls
[ ] Add CB Radio
Cobra 75wx?
Hopefully something with NOAA weather channels?
[ ] Mount High-lift jack Inside
[ ] Second Row Head-rests
[ ] Install Medi-pack Holder
[X] Replace stereo controller w/ something compatible with Android & Pandora
Exterior:
Body
[X] Tackle Rocker Panel Rust!
[X] Realign front wheel well curvature
[X] Pacer Fender Flairs
Lighting
[X] Headlight Lense Replacement
[X] Headlight Relay Harness
[X] 9004/9007 Bulb Conversion
[X] Fog lights (PIAA)
[X] Aux. Driving lights (PIAA)
[ ] Aux. Reverse lights
[ ] Emergency (Strobe) Lighting
[ ] Roof rack lighting, for surround flood/workspace light
Armor
[X] Winch Mount w/ Grill guard and Brush Guards
[ ] Skid plate
[ ] Front Diff / 3rd member protection
[ ] Rear bumper & Tire Mount
[ ] Rock Sliders
[ ] Roof Rack
Recovery Gear
[X] High Lift Jack
[X] HF Badland 12k winch
[X] Front shackles & Mounts
[ ] Rear Shackles & Mounts
[X] Misc. Recovery Gear (includes snatch block and accessories)
[X] Standard tool kit
[ ] On Board Air
Power-train/Drive-train:
Intake/Exhaust
[ ] Cold Air Intake – Sealed w/ Cone filter
[ ] Larger MAF Collar
[ ] Throttle Body Mod
[ ] CPU Chip
[ ] Replace Cat-back Exhaust (Magnaflow pt#11226)
Batteries
[ ] Dual Battery Smart Management (IBS Dual Battery w/ Microporcessor)
[X] Optima Red Top
[ ] Optima Yellow Top
[ ] Relocate Batteries to custom built box outside engine compartment
Fuel
[ ] Add secondary gas tank – Run with toggle switch to dedicated pump/gauge.
[ ] Replace fuel injectors
Cooling/Misc
[ ] Black Magic Electric Cooling Fan
[ ] 2nd Tranny Cooler
[ ] In-line Remote filter for tranny
[X] AGR Power Steering Pump + Upgrades
[X] Flaming River Intermediate Steering Shaft
[X] Rebuild Gear Box
Suspension
[X] 6” Skyjacker lift (w/ dual shocks and JD coil seat buckets)
[X] Optimize!
[X] Dual Piston Caliper Front Brake Upgrade!
[X] Manual Hub Conversion (With Warn Pt#37780)
[ ] C-Clip Eliminator Mod
[ ] Gears (I'm thinking 4.56 in case I go bigger than 33")
[ ] Detroit Truetrac Worm Gear Limited slip (Front)
[ ] LS & Locker Combo! (Back)
[X] Rear U-Bolt bash plate w/ modified Shock Mount
[X] F-150 Leaf Spring Pack Upgrade
[ ] Custom Leaf pack w. full military wrap
[X] License Plate Frames!!!!!
Key:
[X] Done!
[ ] To Do.
{ } Scrapped.
Everything else I figure you can figure out.
Interior:
Temp Gauges
Vacuum Gauge
[ ] Add CB Radio
Cobra 75wx?
Exterior:
Body
Lighting
Armor
[ ] Skid plate
[ ] Rock Sliders
[ ] Roof Rack
Recovery Gear
[X] High Lift Jack
[ ] On Board Air
Intake/Exhaust
[ ] CPU Chip
Batteries
[X] Optima Red Top
Fuel
Cooling/Misc
Suspension
[X] Optimize!
Key:
[X] Done!
[ ] To Do.
{ } Scrapped.
