List of Useful Threads - Engine - PCM - PATS - OBD II - Ignition - Computer issues | Ford Explorer Forums
List of Useful Threads Engine - PCM - PATS - OBD II - Ignition - Computer issues
Status
Not open for further replies.
Rick
Pumpkin Pilot
Staff member
Admin
Wayoutin, Aridzona
'93 XL '20 ST
Callsign
AB7FH
Air Intake System
How to: Build Cold Air Intake 1st gen
How to: Replace Upper Intake Manifold Gaskets 4.0 OHV
How to: Dead Link Removed 2nd gen
Cam - Lifters - Rocker Arms
How to:Dead Link Removed
Engine Diagnostics
How to: Engine No Start Test Procedure
How to: Diagnose No Start / Slow Start Condition
EEC-IV 2 and 3 Digit Trouble Codes
Review: ProScan OBD-II Scan Tool
Emissions
How to: Prepare Your Vehicle for Emissions Test
General Engine Related
How to: Replace Idler Pulley 5.0
How to: Coil Bracket Modification for Aftermarket Intake and Spacer
How to: Replace Serpentine Belt 3rd gen
IAC - Idle Air Control Valve
How to: IAC Valve Cleaning 4.0
Intake Manifold
How to: Install Trick Flow 1" Heat Spacer 2001 Mercury Mountaineer 5.0
How to:R & R Lower Intake Manifold - 1st Gen Explorer
Keyless Entry
How to: All you need to know about keyless entry. 2nd gen
How to: Keyless Entry Keypad Bulb Color Change
How To:
Re Key 2nd gen Ignition lock and keep your keys
PATS Passive Anti Theft System
How to: Program Replacement PATS Key
Everything You Wanted to Know About PATS
How to key new ignition lock to old keys
PATS Key Reprograming Using Forscan
PCM
How to: PCM - Powertrain Control Module - Power Procedure 2nd gen
How to: PCM Power Check Procedure
PCV
How to: SOHC PCV modification thru 2000
Sensors
How To: Replace Leaky Low Oil Sensor 1st Gen
How to: Replace Oil Pressure Sensor 2nd gen
How to: TPS Test Procedure
How to: Clean the MAF Sensor
How to: MAF Sensor Test Procedure
Spark Plugs
How to: Change Spark Plugs 1st gen
Starter
How to: Starter No Crank Test Procedure
Supercharger / Turbo
How to:
Intercooled Banshee/M90 supercharger installation
Tune Up
How to:
Tune up 1999 302 PCV, Sea Foam, etc...
Index thread for:
If you would like to see a valuable thread added to this index please send me a private message.
Status
