- June 17, 2004
- Knoxville, TN
- 98 Limited AWD 302
It sounds like the right time to check the PCV. Make sure it is the proper one, different units have differing amounts of air flow, and restriction. Comparing PCV's at a parts store will find a lot of difference in performance, functions etc. I'd bet yours is the right one, given it's special and requires wiring input. But you might check for the proper function. As the others said, it's desirable because it applies a slight vacuum to the crankcase, to reduce pressure inside, and blowby.
Avoid a catch can, those basically defeat the PCV function, by creating a connection to the atmosphere.
