- May 13, 2000
- Cape Girardeau, MO
- 94 Sport 4x4
SVO said:Cause when this motor is done, it SBF time folks.
what the heck is "SBF time"???
Agreed! and don't forget that Tremec is making a 5spd that is just lke thier 3550, but it's for Jeeps and is set-up for a transfercase but uses a stock T-5 styly bellhousing bolt pattern, which means you can use it behind your 302
Thank Gawd that 410Fortune and others have done detailed swaps to show us where some of the hitches are and what mods work and how easy.
I think a small block is really the way to go, but to be honest the OHV is a pretty tough little number, I can't say that I really have had too many complaints other than reliability stand points, which make me wonder how long will this rebuild last?
Gimp said:Real Men Drive First Gens.
I wish some one would come up with a tranny that would match the 4.0 in toughness.
TheRookie said:Only reason I havent done it is being undecided on a v8 swap
TheRookie said:That would be pretty cool. Just cant afford it. If I swap in an 8 it will likely be a carbed 302
Creager said:Doing a small black swap is probably the most money saving idea yet. Its so practical if you plan on keeping your truck. You and I like most people on this forum dont plan on getting rid of their Explorer in the next 5-10 years, so why not give your metal baby the heart it deserves, a 5.0!
Rhett said:I agree; The goal of people upgrading to a 700r4 (if you can call that upgrading...heheh) is to improve the reliability. But if ya ask me, if you are going to spend the money, you might as well put a 302/351 in there and the transmission to go with it (such as an AOD) and then you'd have BOTH reliability and more power.
Is the 700r4 a manual? I read an advertisement in a Mustang Mag. The TKO 500 (I'm thinking) is claiming that it (due to different shifter positions) will fit vertually any vehicle. Any comments?TheRookie said:They have. It was GM and its called the 700r4 Luckily Advance adaptors has the cure. Only reason I havent done it is being undecided on a v8 swap
