99ex22 Is Crazy! | Page 4 | Ford Explorer Forums - Serious Explorations
99ex22 Is Crazy!
I know a lot of you probably think im crazy for lifting my explorer then lowering it back down to stock then lowering it which I didnt get any pictures of because I only had it like that for a couple weeks. WELL.....
I lifted it again! Same old setup, 1" Body Lift, Shackles, And TT except now I'm running 33x12.5 BFG All Terrains mounted on 15x8 Allied Daytona 51 steel wheels with 3.75 back spacing. EDIT: 4/13/2011 Went spring over axle in the rear and sloped body lift
Mods:
2" TT
SOA
Sloped BL
33x12.5 r15 BFG A/T's
15x8 3.75 backspacing allied daytona 51 wheel
Tow hooks up front
Hella 500's
Trailer Hitch
Mac Intake
Cat back magnaflow
Cobra cb with 2ft fiberglass antenna
JVC hd radio deck
Clear corners
Painted eddie bauer trim black
Records:
Purchased 08/28/2009 With 109,000 Miles-Im the 3rd owner
09/04/2009 New front brake shoes and rotors
09/04/2009 Motorcraft Plugs & Wires
09/11/2009 Flushed out Coolant
09/18/2009 Royal Purple Synthetic Fluids
09/24/2009 Seafoam Treatment
04/19/2010 Replaced Outer Tie Rods and installed camber adjusters
01/02/2011 Replaced Upper Control Arms/Ball Joints
06/10/2011 Motorcraft Plugs & Wires
06/10/2011 Flushed out coolant
06/10/2011 Motorcraft fuel filter
Stock and after me spending half the day detailing it-
1" body lift, shackles, AAL, and TT-
4406 Manual T-Case going in-
Painted eddie bauer trim black, 5.0 emblems, and installed a 95-98 steel bumper-
Went spring over axle in the rear and sloped body lift-
Flex test-
Lots more pictures on the other pages of the thread
thanks man! Ill get one in the morning for you!:thumbsup: it sits MAYBE 1" lower in the front but i kinda like it like that because it was sagin in the rear before
just put the steering extension that came in my 883 kit on and works on my v8 just fine! :)
I love that flex shot on the jeep. The bottom of your bumper is even with his hood. Awesome.
Thanks guys! I like this set up a lot better than any of the others available for our trucks. The ground clearance and departure angle are improved a TON compared to a 3"BL with shackles and the 4" superlift. Nick27 is a genius for figuring this out. If anyone interested in doing this follow this thread here...http://www.explorerforum.com/forums/showthread.php?t=127121
If you don't have a welder you can purchase Superlifts Spring Over Axle Kit here....
http://www.summitracing.com/parts/SLF-1160
Or your local 4wd shop
looks awsome I thought the slant would be way more durastic. I am gonna research if they have this mod for a first gen and if it is in my budget to pull it off. Looks so good I am gonna hijack your Idea. Hope you dont mind
thanks, all you need to do is buy a 3" body lift for your truck and cut them down to the lengths that are listed in nicks thread above. the superlift soa kit for the rear, and f-150 coil seats for the front to get another 2". haha it wasn't my idea, it was nick26's and I don't mind one bit and im sure he does not either. Get Her UP!
Looks awesome. Gives me a lot of ideas for my '00 EB. Actually almost everything you did is what I want to do to mine. I have the lift shackles and the 2" TT done. Just need some add-a-leafs or beefier leafs all together and a 1" Body Lift.
Again, it looks great and thanks for the ideas.
Like the new pics, Looks like comeone was having fun this weekend. I can see broken orange clays + mud= fun
haha yeah it was fun. sorry i got your pm and it was to late
