...I did a little not so technical testing last weekend at Truckhaven of the Trailhead Deflators and thought I would share..
..I usually run into the guy who makes these a couple times a year and I did so again last month...I had him re-calibrate the psi on my deflators from 10# to 15#'s as 10#'s was what I would run my old MTR's at on the Explorer but 15#'s is what I run the current KM2's on the Explorer now..(alot softer sidewalled tire)
...This calibration is where he just adjust the psi of each deflator on an airtank...Basically fills it up and let's the deflator drop down to the current set psi..(shown here testing Stauns)
The following info can be found while searching through their site..(BTW, they make 2 different models..1) Deflates down to 5-20 psi and 2) Deflates down to 15-40 psi )
http://www.trailheaddeflators.com/product.htm
..First, in defense of Trailheads they do note on their site as follows:
The shut off pressure on your tires may vary due to several factors, especially the flow rate of your valve stems.
..They also note..
NOTE: In order for deflators to reliably begin operation, tires must be inflated to a pressure approximately twice the setpoint, e.g.: If the deflators are set to shut off at 10 psi, tires must be inflated to approximately 20 psi or greater
..They also caution..
CAUTION: The greatest care has been taken during manufacturing to insure a quality product. However, if the deflators become dirty internally, they may leak and never completely shut off. They will then need to be cleaned. We recommend the use of quality valve caps at all times when not deflating to help prevent contamination of deflators from dirty valve stems, and that the deflators not be installed on your tire for more than 60 minutes.
________________________________________________________________
...First test was to check my current air pressure after just driving over 100 miles to a filling station a mile or two down the road from camp...
..Next I threw on the Trailhead deflators and headed toward camp knowing that the pole line rd. I was taking was both dirt and partial pavement with plenty of bumps to the campsite..
..:shifty_ey ..If I'm going to have a failure on this test and zero pound a tire out I couldn't think of a better place to do this other than on the way to camp with lots of people waiting with tools and support..
..I got to camp and quickly checked the pressure on all 4 tires and they were all dead on 15#'s with my tire guage. (keeping of an accurate gauge or two in each truck is a must offroad especially with lockers)
..This is a pic of the deflator hanging out to the side on my Explorer's wheels..On these wheels I would only run down a fire rd. or similar while deflating..
..My Rangers wheels with the valve stem tucked in would allow for more airdown road options while driving with these deflators on..
..Ok but Maniak came up with an idea...We will try this out on his dual tire equalizer set up.. (Something like this but made for low pressure and offroad use
http://tireairpressuregauge.blogspot.com/2011/08/psiclops-xl180.html )
..This test worked also as it dropped both tires down to 15#'s...
..But there was another unofficial result which happened by mistake...Maniac pulled the Trailhead Deflator off at 17#'s to verify the pressure with another guage...We used the same deflator to see if it would in fact start and continue to deflate from 17#'s to 15#'s..
...It was a success..:biggthump...I must add though that the dual tire deflation in combination wih one Trilhead Deflator seemed to take forever as you are deflating 2 tires out of a single pinhole..
...Again, this was a non technical test and it was at and near camp...Your results and reliability may vary...
..For those who want to do some research on 2 and 4 wheel Equalization, this page is a long read with a bunch of info..(Not promoting them just the info
http://www.4crawler.com/4x4/ForSale/4air.shtml
