Welcome to the Forum CRFrizzell. :wavey:HELP! I just purchased a brand new 2013 XLT explorer. I was messing with the mytouch screen and was tryign to add new key code. it asked what I wanted to do with the other and I said delete. So now there is no code at all. Am i screwed? How do I get the facotry code back in?
So what you're saying is that when you try the setup and enter the original code and within 5 seconds when pressing the (1-2) button, it gives you an error and won't let you proceed with entering a new code? Remember all entries have to be made within 5 seconds of the previous entry.PS. Im telling you in the 2013 it lets you delete it and it doesnt come back. I mean its Not there at all. Code doesnt work on doors, no code in file. No place to put it back in or restore. No place to add a new one. You have to have the original in there for it to allow you to add.
Looks a dealer trip is in order for the OP.I have been looking online but haven't found any info on this or in the manual, I guess if it comes down to it you could always unhook the battery and I would guess that it would reset it back to the factory code...??
....I found the 5 digit number that I need to unlock my Explorer. Hopefully this info will help anyone else in the future who may need it. I looked under where the gas and brake pedals are located. I used the flashlight with my phone and there I "easily" saw a 5 digit number with the letter "L" after it. I hoped the "L" stood for "lock". I put in the 5 digit number and low and behold....my door unlocked!!!
jhcarter....thank you also for your advice. Your time was appreciated also. I'm just glad I had an easier and less time consuming outcome!
Welcome to the Forum breezy062.:wavey:This also worked on a 2012 Explorer Limited. Thanks JFBK!
Have you checked the card in the back of your owners manual?????
If you are not sure if you entered the correct factory code and you can't find the card, check out the following thread for my post and picture.Do after having my explorer for nearly three months, I finally set my own keyless entry code. After a few days I decided I didn't like that code and I wanted to change it. I entered the factory code on the screen to get into the screen where the new code can be entered. After I entered the code, there was a prompt that asked if I wanted to add, change or delete, I think. Expecting the result of this prompt to be another screen, I touched delete and then I think it went back to the screen asking for the factory code. Now when I enter the factory code, nothing happens - like I've entered the wrong code.
So now I'm looking fit advice on how to fix this.
Thanks!
http://www.explorerforum.com/forums/showthread.php?t=320589
You are not the first to have done this. There is another thread on this forum where a member encountered the same issue. I haven't looked for it yet.I have the factory code and I entered it correctly.
Pages 82-83Note: The factory-set code cannot be associated with a memory setting.
The factory set code will work even if you have set your own personal code.
