jack1.1
- July 17, 2002
- StL
- 1998 Explorer Eddie Bauer
1998 EB 5.0
sniper tune (87 octane)
catback exhaust, no other mods
Pings under load sometimes, so here's the setups.
K&N panel filter in stock box and stock rubber inlet tube.
or
K&N cone filter with stock rubber inlet pipe.
or
K&N cone filter with chrome metal inlet pipe.
or
this is what I am running now, a K&N panel filter in stock box with a chrome metal inlet pipe.
I did an experiment last summer (with the data logging) with the cone filter and the metal inlet tube, thinking low restriction and my inlet temp was 151 degrees. I swapped out, back to the stock box and rubber inlet and my inlet temp went down to 108 degrees. So I have been running the stock setup for quite a while.
Could it be that since it is 20 degrees here now that the air is too dense and I am leaning the car out too much, and should heat up the air (i.e. go to the cone filter and metal pipe for winter)? I figured my MAS did adjust for that, but am I missing something?
Or is my tune just off?
Sorry for the rookie questions, I'm learning.
Thanks for the input,
Jack
or
or
or
Jack
