C420sailor
- July 29, 2008
- Long Island, NY
- 98 XLT SOHC, 99 EB 5.0L
Just posting a request for info on an interesting issue—more like a mini case study.
99 V8 AWD, 138k. Ran flawlessly, no codes, trims around 0. Took her on the road to my place down south. Got there no problem, drove her around town a few days while i did some work on my 98 Ex down there.
Ian’s rain/wind bands rolled through, and it POURED. the truck sat through that for about 36 hours.
After the storm blew through, I packed it up for the drive back. It started and ran great. Drove it a mile to go get some food, then another 3-4 miles to get gas before leaving town. Shut the truck down at the pump. Pumped 17gal of 87 octane in, and started her back up. Started fine, idled well for 60-90sec, then quit. Attempts to restart were met either with cranking and no fire, or the truck would start and immediately idle horribly (well below idle rpm, surging, popping, clunking, etc) before dying within seconds.
P0320 code, pointing toward CKP sensor.
I looked at the sensor and tone ring. Looked good visually, didn’t remove. No visually apparent damage to wiring. I disconnected and reconnected the negative terminal for the hell of it.
When the truck did fire and run horribly, the tach functioned and I received accurate RPM via OBD2.
I called for a tow, and the truck sat for 45 minutes while I thought about the problem. I could hear the fuel pump prime with key on, but decided to swap the relay anyway. The truck then started, ran horribly for 3-5 seconds, and then smoothed out like nothing had ever happened. I drove it 400 miles home without a single hiccup. I refueled with no issues, so I think that rules out an evap purge valve issue.
I plan to do some checks, namely check fuel pressure, but the trims are still flawless and all other sensor readings look good.
My thoughts are the following:
1) Intermittent CKP/wiring issue
2) Intermittent fuel pump relay
3) Intermittent fuel pump
4) Contaminated fuel
In a vacuum, I’d lean more toward 1 or 2, but the fact that the truck gave it up within two minutes of me pumping fuel into it really makes me think.
Possibly a small amount of water from the storm that took time (45 minutes) to be absorbed into the miscible ethanol?
Thoughts?
Thoughts?
