Mountaineer Headlight | Ford Explorer Forums
Jonathan46237
Indianapolis, Indiana
2002 mountaineer
I decided to try painting my headlights and using the 3m Headlight restore
You can see the damage from years of sun and driving
Here is sanding with 50 grit, I suggest once you get to the wet sanding stage and you think you are good, go back and do it two more times then buff, i also used a finishing compound to get better results
Finished, The headlights look better but dont expect a brand new headlight, there is still some haze but does look much better.
Looks really nice! May be a spring project for me.
STU
I read about someone using a clear coat after doing their lights and it helped with fine scratches and made it look even better. Yours is a MAJOR improvement compared to what you started with;) Great job!
:thumbsup:
Looks good!
Looks great! I hope you did not go as low as 50 grit, that is way more aggressive than necessary and could be part of the reason you still have some haze. I have never seen a set that could not be corrected with 600 grit or better!
I'm sorry i left a zero off, 500 grit, 800, a wetsand with I believe 2000 then a rubbing compound. 50 grit sure would tear some stuff up
Looks really good. :thumbsup::thumbsup:
I love the 3M kit. I have tried other methods that are guaranteed to work but they never do. The 3M kit is the way to go!!
