rob7.3
- April 4, 2014
- 2003 Explorer
02 exp 4.0, replaced all timing chains and put back together and it started sounded good. Coolant leak at thermo housing shut it off and fixed but now it won't start. Pulled everything down to find the can had moved forward again off the rockers. This is the second time its moved. What am I missing? Can't figure it out. No thrust washers, plasti guage check shows its in specs. Any ideas or suggestions please.
