Thats alot of codes! Reboot PCM. If that doesn't work replace it.
I have a 94 Eddie Bauer Ex 234+K miles. I was getting alot of codes as well. One of which was Code 513 (Faulty PCM), I was able to pull a PCM from a junkyard for only $50. Easy to pull and install. Try to find same year Ex and pull it yourself.
Also if you have ATF in your vacuum lines, you need a new Tranny Modulator installed. A local shop should be able to do it for a $100 plus parts. While you are checking your vacuum lines for ATF, look for a loose or disconnected hose. They tend to blow off when the truck backfires due to ATF in the intake.
Pull a part In Augusta GA has a 93 Ex on site.
329 Sand Bar Ferry Rd, Augusta, GA 30901
Make Model Year Row Location Date On Yard
FORD EXPLORER 1996 300 Augusta06/14/2007
FORD EXPLORER 1995 302 Augusta06/20/2007
FORD EXPLORER 1994 301 Augusta06/18/2007
FORD EXPLORER 1994 310 Augusta08/08/2007
FORD EXPLORER 1993 312 Augusta08/13/2007
FORD EXPLORER 1992 312 Augusta08/13/2007
FORD EXPLORER 1992 301 Augusta06/18/2007
FORD EXPLORER 1991 314 Augusta05/30/2007
FORD EXPLORER 1991 300 Augusta06/14/2007
FORD EXPLORER 1991 303 Augusta06/23/2007
FORD EXPLORER 1991 304 Augusta07/05/2007
FORD EXPLORER 1990 309 Augusta07/31/2007
HEY, First time on forum
I have a 93 EX 4.0 Auto. Rough low idle,black smoke from exhaust.
Fuel pressure checked at 12 psi key on 35 psi running holds good pressure.
Pull codes with cel 117,122,112,513,565,556,629, and 566.
Any info would be helpful. Thanks
117 (O,M) ECT sensor is/was low or grounded - ECT
122 (O,M) TP low (possibly grounded or open circuit) - TPS
112 (O,M) Intake Air Temperature (IAT) sensor is/was low or grounded - IAT
513 (O) Replace processor (PCM) (internal failure)
565 (O) Canister Purge 1 solenoid/circuit failure - Solenoids
556 (O,M) Fuel pump relay primary circuit fault - Power / Fuel Pump Circuits
629 (O,M) Torque Converter Clutch circuit fault - Transmissions
Hope this helps!
