James909
- January 17, 2008
- Long Island, NY
- 1994 GMC Yukon 2 Door
I installed a '99 rear end in my '92 Ex recently. The rear end is a limited slip with 3.73 gears and 25k miles. Before I installed it I drained and refilled it with Mobil 1 75w 140 oil and did not add friction modifier because I was under the impression that the Mobil 1 already had it. Now it's installed and working properly, it doesn't make a sound but when I come to a stop or close to a stop and then accelerate through a turn (like when pulling into a parking spot) the rear end has a moderate vibration. It's not wheel hop or anything that severe but it is definitely noticeable. I have never owned a car with a LS so I don't know if this is normal or not. But when I changed the fluid I inspected everything and nothing looked abnormal but I don't know much about differentials except how they work. Is this vibration a sign of serious problems or is it just normal LS chatter? It's not really bothering me that much, it only happens occasionally but I don't want to do any damage. Can I just put some friction modifier in even though I think Mobil 1 already has it? Will adding more friction modifier decrease the LS holding power? Thanks for any advice. -James
