jd4242
- October 15, 2008
- va beach
- 92explorer&94 ranger
how do you adjust a a4ld shift points?the problem im having is when you are full throttle only it will hit the rev limiter before it shifts.it will shift by hand fine or under normal driving it shifts fine,only full throttle.ive checked to see if the vac lines are on and also have pulled the kick down cable off to eliminate all those.my buddy runs a trans shop but he has been slammed but he said because of all the motor work and big cam that it may have changed the vac pressure and there should be a screw on the vac modulator on the side of the trans but i cant find it?its a brand new trans with a shift kit,any help or suggestion would be great.its getting old trying to race people and having to shift by hand or the fuel cut off kicks in:thumbdwn:
