1992 trans codes for a4ld? Won't shift | Ford Explorer Forums - Serious Explorations
cr500guy
san diego
1992 prerunner
I have a 92 a4ld rebuilt it (read the diary sevveral times but apparently not enough) trans go kit, patc upgraded kit, boost valve, sonex,bell housing work, all the trango mods,etc. sprags,& solid spacer sonnex kit. measured/adjusted all. the problem is that it won't shift into 2nd, replaced the govenor-no cigar, readjusted the bands per transgo, it will shift if you lift the pedal. if shifted by hand it shifts. the engine light will come on sometimes going into od. I've have an adjustable mod valve but have not played with it yet. which way do you turn it? did the recomended test for the cutback valve, the needle did'nt move except just a tiny bit in the lower vacumn test. I need some help from you experienced guys. all was clean and torqued. Thanks guys
